Subject: Victoria Updo?
Tammy opened this issue on Jun 01, 2001 ยท 6 posts
Tammy posted Fri, 01 June 2001 at 3:26 PM
Will the Victorial updo work with 160mb of ram, 8 allocated to Video. I have the standard resolution textues not the high ones. Daz recommends 180 so Im not too short and thought Id ask those of you who had it. Also what size is the download file?
whoopdat posted Fri, 01 June 2001 at 4:26 PM
It'll probably work. If you have enough virtual memory, or if you use something like Ram Booster to defrag the ram before rendering, I think it'll work. And um...lemme see...file size is...just a touch over 4 megs.
Tammy posted Fri, 01 June 2001 at 6:00 PM
Thanks for the reply I emailed Daz to see what they thought, I wonder why it uses so much RAM? The map sizes? I have rendered stuff with a much higher polygon count than that.
Tammy posted Fri, 01 June 2001 at 7:21 PM
Thanks whoopdat I went ahead and got it and thought Id post here that it did work on my computer with the medium resolution maps in case anyone was interested. I only had poser running and I always shut all the extra stuff down running in the background that may have helped but it was no slower than some of my other hair products really. I have attached an image I did with it, no postwork using one of my Vicki2 character pack characters.
BillyGoat posted Fri, 01 June 2001 at 9:15 PM
You should see it on Dana!! It's incredible on her.
Tammy posted Fri, 01 June 2001 at 10:14 PM
Thanks Billy Ill have to try it out on her.
