RLG1034 opened this issue on Jun 01, 2001 ยท 12 posts
RLG1034 posted Fri, 01 June 2001 at 3:54 PM
From this rather simple question you will be able to tell I just got Raydream, and that it is testing the limits of my sanity. All I want to do is create a simple pyramid. And if anyone can tell me why they could'nt include one in the primatives pallet.
MarkBremmer posted Fri, 01 June 2001 at 6:07 PM
twillis posted Fri, 01 June 2001 at 6:08 PM
Would a vertex cube work? I mean, start with a cube, then weld the top four verticies together (I'm in Carrara, not sure if RayDream has the same sort of vertex modeller). --Terri
smcquinn posted Fri, 01 June 2001 at 9:39 PM
Yes, the Carrara VM method works better, I think. The spline pyramid is tricky at the peak, but the VM peak is a single point. Use a layers list of flat shaders applied to each of the faces. SMcQ
willf posted Fri, 01 June 2001 at 10:34 PM
The other option is to start with the SplineModeler as Mark suggested. Instead of the envelope create another cross section at the end in order to make the tip. Select the end cross section & scale it to .1% (don't use 0). That's the fun part, many ways to skin the cat.
RLG1034 posted Sat, 02 June 2001 at 5:21 PM
Thanks all. Your right willf all of these ways worked with great results. Makes me feel pretty bad when I could'nt even stumble on one of them on my own. Oh well guess I'll just have to keep plugging away at it. Thanks again. :))
willf posted Sat, 02 June 2001 at 10:25 PM
No need to feel bad, working in 3D is quite odd at first. Funny, we live & work in a 3D world but when going from 2d to 3d art it is hard to orient yourself to the working space. Just ask-away, you will almost always get some help (unless nobody else knows either!).
AzChip posted Mon, 04 June 2001 at 12:37 PM
One other tip -- when you're building a pyramid in the free-form modeler using Mark's technique, be sure to set the grid to "snap to," that'll make sure the point of the pyramid is a single point.... And keep on asking; that's what the forum is here for!
twillis posted Mon, 04 June 2001 at 1:05 PM
That, and sharing our favorite cheddar cheese recipes. Actually, I like these kinds of questions. It's really neat seeing all the different approaches. Do you suppose one could make a pyramid as a formula object? I was playing with simulating pyramid bricks ausing a formula shader a couple of months ago, but the object itself was a vertex object.
twillis posted Mon, 04 June 2001 at 1:25 PM
willf posted Mon, 04 June 2001 at 4:26 PM
UUUGGGHHH!!! I got "into" art to get "outa" math. Those formulas make my head spin! Good start on that pyramid formula twillis.
twillis posted Tue, 05 June 2001 at 7:34 AM
Well, the corners are screwed up, and I never went back to fix it. I came to Carrara via POV-Ray, which is all formulas. Also, my art background is technical drawing. Anyway, if I had been able to use descriptive variable names, my formula probably would make more sense (there is apparently a limit to how many character you can enter in the box).
