Blackhearted opened this issue on Jun 11, 2001 ยท 17 posts
Blackhearted posted Mon, 11 June 2001 at 10:37 AM
Is this possible? Jim, if youre reading this -- Supermodel Vicky is amazing, I love the work you did with her body. She looks far more realistic and appealing than the standard vicky models. However, her head is a little strange - its great for some characters, but its just isnt very versatile for what I need it to do. Is there any easy way to graft vicky 2.0's head onto smv's body? If this is possible, I would probably stop using vicky 2.0 altogether :) If its not too complicated, can someone describe the steps necessary to either graft the head over, or just copy the vicky 2.0 morphs over (if possible)? Jim, with the prettier vicky face morphs out in 2.0, do you have any plans on releasing a 'vicky 2.0 smv update'? Im sure you would make a lot of people very happy if they could combine the awesome body of SMV with the flexible, cute face of vicky 2.0. Thanks
Jim Burton posted Mon, 11 June 2001 at 11:11 AM
Blackhearted posted Mon, 11 June 2001 at 11:29 AM
I read your post about SMMV earlier, but you said it wouldnt really be quit like SMV because the body isnt exactly the same (just similar), and the hands and feet would remain vicky's. Is there any way to keep the exact supermodel body and just transfer the head or head morphs? Like a modification to SMV's head rather than modifying vicky's body to look like smv's?
Jim Burton posted Mon, 11 June 2001 at 12:06 PM
You should be able to se Vickie II or Vickie I head morphs (only) on SMV, you would have to copy and paste them rrom the CR2, or use Morph manager or CR2 editor to get them into SMV's CR2. Actually, as I think about it, you could probably build a head you like on Vickie II and export the head as a morph object too, and fit that to SMV's head, setting it to 1.00 should convert the entire head (including teeth) to th enew look. I'll try that and see if it works. The Vickie II CR2 isn't redistributable, remember, so I can't put the morphs in a SMV update.
Blackhearted posted Mon, 11 June 2001 at 12:59 PM
Jim, I tried what you suggested - moving the vicky II morphs over to SMV with morph manager, but when I apply them instead of converting the head it just makes a sortof half vicky/half smv face that looks pretty strange.
thgeisel posted Mon, 11 June 2001 at 1:07 PM
blackhearted: i aggree to you, its just her face ,that i would change.and with the vicky2 head on her , it would be be fantastic!
ar2g posted Mon, 11 June 2001 at 1:12 PM
Jim thank you for the thought of letting us SMV purchasers get this update for free. It is very generous of you :) AR With his bbay receipt ready
soulhuntre posted Mon, 11 June 2001 at 1:17 PM
I LOVE SMV. She looks great - but I need to stay closer to "stock" with my models for other reasons. What I am really hoping for is a SMV morph for Vivki2 ... so if I zero'd it all out and set "SMV" to 1 I';d have SMV, and still access to all the other stuff.
Jim Burton posted Mon, 11 June 2001 at 4:55 PM
Attached Link: http://digitaldreams.bbay.com
Jim Burton posted Mon, 11 June 2001 at 4:58 PM
for "Your own your own" read "Your on your own"! And "SMV oweners aren't going" Proof-reading is a wonderful thing, I'll have to try it someday!
Blackhearted posted Mon, 11 June 2001 at 6:02 PM
Thank you, thank you, thank you! You rock, Jim.
Jim Burton posted Mon, 11 June 2001 at 6:24 PM
Your welcome! SMV is still a single purpose figure, but at least now she can be a asian supermodel, or a black one, or whatever!
soulhuntre posted Mon, 11 June 2001 at 9:09 PM
Ok... so I understand... This is a SMV that can have VII morphs moved onto her - but this is NOT the Daz VII mesh, right?
Mesh_Magick posted Mon, 11 June 2001 at 11:01 PM
soulhuntre posted Mon, 11 June 2001 at 11:32 PM
I suspect that with the right tweaks to the morphs that are already there, VII can be tuend to look really hot. It just needs someone to do it :)
Jim Burton posted Tue, 12 June 2001 at 7:35 AM
soulhuntre posted Tue, 12 June 2001 at 7:38 AM
You're right ... it's easy to see the difference for sure. SMV is a great work. We have just decided to standardize on the Vicky 2 geometry for now - and track Daz when they go to Vicky 3 whenever. It is just too important for us to have continuity. Ah well... I'll keep twiddling them dials myself and see if I can get close at least :) Again, GREAT work - it just isn't for us :(
