dg3d opened this issue on Jun 12, 2001 ยท 11 posts
dg3d posted Tue, 12 June 2001 at 10:23 PM
KenS posted Wed, 13 June 2001 at 2:14 AM
interesting image, if you hadnt of said eclipse, I would have mentioned getting rid of the shadow on the planet. The nebulas look ok, but really stand out in the image. too bright maybe. especially if you use the planets backside shadow in conrast to the 'brghtness' of the nebuli. Id like to see how this progresses. Ken
EricofSD posted Wed, 13 June 2001 at 7:06 AM
Way to go, P. looking good. I agree with Ken's comments. Maybe one way to deal with the eclipse is to make the shadow larger and give it a fuzzy edge. I haven't tried it yet but can you make a moon sphere that's got a fuzzy edge on it and positioned for a large shadow (which hopefully will be fuzzy too), then put the actual moon sphere over it with cast shadow unchecked so the moon looks real?
dg3d posted Wed, 13 June 2001 at 9:04 AM
Thank you both, i will try this, i have done some retouch on the nebuleas this morning and try again tonight. I will post it tonight maybe. The moon is already fuzzy, but if you look at a distance planet, the moon will do a black dot and you won't see it fussy.
dg3d posted Wed, 13 June 2001 at 7:35 PM
I decided to get rid of the eclipse for the moment and concentrat on the Nebulae. So what do you think about those one. Pleiades
KenS posted Thu, 14 June 2001 at 12:39 AM
100x better, great work Pleiades, this image is much better. Ken
dg3d posted Thu, 14 June 2001 at 5:43 PM
Thank you Ken, very appreciated. Pleiades :)
RLG1034 posted Fri, 15 June 2001 at 7:25 PM
Thats really good work on the nebula, how are you getting that effect, it looks great. If you decide to put the eclipse back in you might want to give negative lighting a try. You can get really good ecliptic effects with negative lights.
dg3d posted Sun, 17 June 2001 at 7:09 PM
KenS posted Mon, 18 June 2001 at 3:16 AM
wow, thats so great looking, you did a awesome job reworking the nebula. Ken
