Sorry for another WIP post only a day after the last one. This took more time than I realized and even though the difference is somewhat minor, I think I like it. I want to get the tweaking of these existing textures finalized before going on to build the scene, (this one is temporary) and maybe build a few more objects that will compliment the VCFS, with out changing the look to much. :-) A couple things I'm not sure of. Did I make the shield to reflective? Does the slight grain to the shield's bump map add to it or should I try to smooth it out? I like the way the reflectivity on the gold highlights for the skirt came out. However, the finer detail designs closer to the bottom of the skirt seem to suffer a little. I could make the texture a higher res and clean up the details, should I bother? Or maybe just remove the smaller paterns from the skirt entirely? Also, now the cloth part of the skirt looks a little "off", I could add a woven cloth like bump map, or maybe even make a new texture for the cloth part, keeping the gold highlights and design work? Anything else? If anything seems off to you, please make a note of it, nit picking allowed! In general, I like how it's shaping up so far, but additional perspectives are very important and much appreciated. :-)
I know it can seem a minor detail, but your astrological wheel is inversed, like in a mirror Great work, btw :)
Thanks Merlin! That's the texture map that comes with the first texture pack for the Victoria's Changing fantasy Suit, with a lot of tweaking. I'll have to go into PSP and see if I can mirror it. :-)
