Subject: Lara Croft
Estruch opened this issue on Jun 27, 2001 ยท 3 posts
Estruch posted Wed, 27 June 2001 at 1:36 PM
Lara Croft not have foots... This is a bug?
JKeller posted Wed, 27 June 2001 at 3:01 PM
Depending on which version of Laura Croft you are referring to (there are several), I believe the boots are the foots... as in the creator did a 'replace body part', replacing each foot with a boot. In order to fix this you may be able to Edit Menu > Restore > Figure (? - I think that's where it is - I'm not at a machine with Poser on it right now), but that may produce some other side effects. Hope this helps.
AlleyKatArt posted Wed, 27 June 2001 at 3:10 PM
I think he's talking about the new version in the freebie area. Turn off the Inverse kinematics. Her feet will attach to her legs then.
Kreations By Khrys
