Forum: Bryce
Subject: any one know how to flesh out Poser textures in Bryce?
tajshan opened this issue on Jun 29, 2001 ยท 5 posts
tajshan posted Fri, 29 June 2001 at 10:48 PM
Poser figures can be quite extravagant when render in Poser 4, but when imported to Bryce 4 the texture looks kinda dull when rendered. Does anybody know how to sharpen them in the texture editor in Bryce 4?
trelihan posted Fri, 29 June 2001 at 10:55 PM
it is hard to do....the lighting has to be just right..check out my gallery postings and see if the effect is what your looking for,,,,alot of the posts are done in bryce.
KenS posted Sat, 30 June 2001 at 12:42 AM
what youll need to do is select each mesh part and in the material lab, turn the ambience down, by default, Bryce sets ambience at like 19.8 or somethng, which is why figures look washed out.
Phantast posted Sat, 30 June 2001 at 10:11 AM
Attached Link: http://www.chesco.com/%7Ecjcigas/tutorial/grouper/index.html
The problem is that Bryce usually sets ambience to black and 100%. You need to map the ambience channel to the texture and set it to a sensible value (depends on the diffusion). Contrary to KenS, you don't have to go through each mesh part. Use Grouper and you can do all parts that share a common texture at once.
KenS posted Sat, 30 June 2001 at 12:58 PM
Thanks for the link to Grouper, I dont know how I let a utility like this one slip by me. Ken
