iberika opened this issue on Jul 03, 2001 ยท 6 posts
iberika posted Tue, 03 July 2001 at 10:54 AM
Is it possible to make a sketch rendering (the one that looks like pencil drawing) outside the main Poser window? - so that I can render larger images with more dpis :-) gracias
breathless posted Tue, 03 July 2001 at 12:31 PM
render as 1 frame animation, with sketch style render -- that way you can set a larger window size, then rescale in Photoshop or other image editor to scale the image down and increase the dpi.
Don posted Tue, 03 July 2001 at 2:26 PM
Attached Link: http://Cyber-Fyber.bbay.com/images/CF-DLfiles/SketchDesignTutorial.pdf.zip
You can download my free Sketch Design Tutorial at this URL. It shows how to get very high DPIs. and how to combine different Dispaly Settings (smooth shaded and wireframe, etc.) in one render. You can also see 88 different and new sketch design presets at Bbay, including traditional media and comix styles... and a pencil style superior to the standard P4 preset. de nada -3Donpam posted Tue, 03 July 2001 at 4:36 PM
Don, I may be missing something, but following this tutorial, Poser still does the sketch render in the main window, not in the new window at the larger size. The images do have the higher dpi though, so that is a big help! I still wish I could render them larger. Maybe in Poser 5
Don posted Thu, 05 July 2001 at 12:46 AM
Pam- Under the Render menu, choose Render Options. You will see a place to render to a new window. In those settings you can specify the size of the new window where the render will happen and at what resolution you want. Choose your Sketch Design style. Choose Sketch Render under the Render menu. A new window will open and the Sketch Render will appear. If the window and resolution settings are high you will see a corner of the rendering taking place. Once complete you can scroll to see it all. Save the image. open in an image editor like Photoshop and save it in that program. The file size will reduce and you will be able to do post rendering work. -3Don
pam posted Thu, 05 July 2001 at 6:06 AM
well, perhaps my Poser has a bug in it :(
