Subject: probs with the olympian mappack
thgeisel opened this issue on Jul 08, 2001 ยท 5 posts
thgeisel posted Sun, 08 July 2001 at 2:37 PM
bought the olympian mappack today.have some probs!after applying a matpose to the cloth i have to parent the clothfigure new to viccy.the sandals move away,some of the poses deform the skirt. Anyone else the same prob???
Dmentia posted Mon, 09 July 2001 at 9:56 AM
Hi there! the problem you're having is normal, unfortunatelly. you would have the same problem with vicki or michael if they were conformed rather than stand alone. if you've ever accidentlly applied a pose to a conformed figure rather than the base figure then you'll know exactlly what I mean... the solution is fairlly easy. 1. you can apply the mat pose prior to conforming. or 2. you can apply the mat pose and then reconform. If you choose the 2nd, then be aware that any tweaking you did to it after the origional conform will be lost, so the best thing to do is if you tweak an element go to object in your pull down menu and lock the actor, this way when you reconform your additional data will not be lost. hope this helps :)
thgeisel posted Mon, 09 July 2001 at 10:20 AM
thanks,thought there would be another solution. by the way, very nice textures :-))
Dmentia posted Mon, 09 July 2001 at 10:26 AM
thanks for the compliment, and beleive me, I tried every trick in the book as well as a few not in the book to work around the conforming figure mat pose problem...I guess it'll be my request for poser 5 that poses in general do not physically effect conformed figures in any way other than the way they are supposed to...If you look at the mat pose in text editor you'll see that it in no way tells the figure to change, thats just poser playing games with it :)
thgeisel posted Mon, 09 July 2001 at 2:16 PM
looking for something in the matposefiles was something I tried first:-)) and you are right!nothing!!
