kennect opened this issue on Jul 10, 2001 ยท 3 posts
kennect posted Tue, 10 July 2001 at 9:36 PM
OK, maybe someone around here can answer this question...Apparently, I did something screwy with Poser but I can't figure out what it is...Every time I go to open the program it gives me a window saying it can't find "ground default texture"...After saying no, to an ongoing search the program finishes loading simply to ask me the same thing again...After another "no", I am asked a third time as I try to open an existing file...I have searched through the program trying to find this file and I can't come up with anything...Is it just me or is there possible anyone else out there that has experienced such??? Thanks
bebop posted Tue, 10 July 2001 at 10:22 PM
The file should be in Poser 4/Runtime/Textures folder. If it isn't you have probably moved it or deleted it. It's not a very important texture. The easiest solution is probably just to make a neew tex and call it ground default texture. tif and put it in that folder
kennect posted Tue, 10 July 2001 at 10:31 PM
Thanks, Not sure how I screwed it up but I did...
