Forum: Bryce
Subject: How do i apply clipping bracket to a terrain?
shutterb opened this issue on Jul 11, 2001 ยท 6 posts
shutterb posted Wed, 11 July 2001 at 10:25 PM
When it try to clip the bottom of a terrain, I adjust the clipping bracket and the bottom of the terrain goes white in the preview window. I click the check mark on the bottom of the terrain editor, and go back to the scene and the bottom of the terrain is not clipped. I go back to the editor, and the original preview is back in the preview window. The action with the clipping bracket did nothing. What am i missing?
tonygentry posted Wed, 11 July 2001 at 11:13 PM
Sure you are not adjusting the gradients slider? you need to grab the bottom edge of the bracket not the colored area. It should turn red not white. If this wont work I say reload your software. Tony
shutterb posted Wed, 11 July 2001 at 11:30 PM
Yes that worked just as you said. Thank you a lot. I was not adjusting the bracket. I knew it would be something simple.
EricofSD posted Thu, 12 July 2001 at 2:07 AM
Ok, tony, I just learned something too. Had the same problem. Thanks.
tonygentry posted Thu, 12 July 2001 at 6:02 PM
Your welcome guys. I did the same thing as you once. Sounds like you learn like me, just point and click, lol. However, when you learn by trial and error you wont forget it. chow Tony
Sihn posted Thu, 12 July 2001 at 10:35 PM
God bless you! I've been trying to figure that out for ages! running off to go play in the terrains
