Subject: flash export on poser pro pack
nicociri opened this issue on Jul 11, 2001 ยท 3 posts
nicociri posted Wed, 11 July 2001 at 11:19 PM
it's probably some stupid detail, but i want to change how many colors should poser use to create the SWF but when i change the default (4) and try to click ok, a dialog pops saying i can only use numbers. tried to patch the pro pack to SR2, but then other problem appears, it requests the serial number again but this time says it's invalid. just what the #$%/%%$# im doing wrong? i had poser 4.0.3 before any pro pack. thanks
Kerrwolf posted Thu, 12 July 2001 at 5:18 AM
I'm not sure about the SR2 problem, but with the Flash export, you have to decrease to # of frames per second in order to increase the number of colors. Try changing the frame rate to 12fps and use 16 colors. These settings usually work well for Flash animations. Kerrwolf
nicociri posted Thu, 12 July 2001 at 11:04 PM
ir was a localization problem. Im using a windows set on spanish and therefore, the commas and points has different meanings. by default, poser puts linewidht like "1.2345" and in spanish it should be "1,2345". that's why it tells me to use only numbers. thanks anyway...!
