Subject: Saving to The Library
Tuesday opened this issue on Jul 13, 2001 ยท 5 posts
Tuesday posted Fri, 13 July 2001 at 7:32 AM
I just wondered if anybody could answer a question that's been bugging me. When I save things to the library the thumbnail picture isn't a rendered picture, I was sure it said in the manual that the thumbnail picture would be rendered, but mine never have been. Has anybody else had this? it's not really a problem, but if it should be rendered I'd be interested to know why I'm not getting a rendered image.
dolly posted Fri, 13 July 2001 at 7:34 AM
did you render the figure or what ever first if not try that just render a quick one then add to library and that should be it
Eowyn posted Fri, 13 July 2001 at 8:01 AM
  1. Render the image you want in the thumbnail. 2. Choose "copy picture" in the edit (?) menu. 3. Choose "paste onto background" in the Display menu. 4. After that, turn the camera so that you can only see the rendered image. 5. Save your figure (or pose.. etc) in the library.
Tuesday posted Fri, 13 July 2001 at 9:20 AM
Thanks I'll try that, I always assumed it was an automatic proces.
doozy posted Fri, 13 July 2001 at 11:44 AM
  1. Render the image you want in the thumbnail. 2. Choose "copy picture" in the edit (?) menu. 3. Choose "paste onto background" in the Display menu. You can skip 2: after 1 go directly to 3. 4. After that, turn the camera so that you can only see the rendered image. I have a camera dot set for this. 5. Save your figure (or pose.. etc) in the library.
