Subject: Victoria2 and Vicki's missing eyelashes!
PiX opened this issue on Jul 13, 2001 ยท 4 posts
PiX posted Fri, 13 July 2001 at 4:44 PM
Hey gang I'm not a newbie -- but I'm new to DAZ products and for some reason neither Vicki's or Victoria's eyelashes show up. See the picture that I made of a nice crone and viola NO EYELASHES! * grumble * I've added transmaps, removed transmaps -- turned everything to black on the eyelashes, twinked the trans on everything one way and the other and nothing works. HELP!! Thanks!
Marque posted Fri, 13 July 2001 at 5:39 PM
Go to your dials and dial the eyelashes to 1.0 Marque
stallion posted Fri, 13 July 2001 at 5:41 PM
goto tool bar >Render >Materials select the eyelashes set the transparency min to 100 set the transparency max to 100 set the transparency falloff to 0 be sure the trans map is loaded and the texture map is loaded render and see if that work stallion
You might as well PAY attention, because you can't afford FREE speech
egaeus posted Sat, 14 July 2001 at 11:36 AM
I've noticed that some texture maps seem to do this -- make the eyelashes not work. I usually set the eyelash texture to a head tex with which I know the lashes will work. Mike
