veamon opened this issue on Jul 16, 2001 ยท 5 posts
veamon posted Mon, 16 July 2001 at 11:35 PM
ok, i wanna be able to add a custom tattoo or scar or whatnot to these textures, and when i load it up in photoshop and add it then use that copy to texture the figure, usually the skin for the chest and front is on the back, and same for the back..i use the same method as i did with p4, just loading it in photoshop and adding whatever then applying that one to the figure and it worked fine..ideas?
Daio posted Tue, 17 July 2001 at 11:37 AM
I'm not sure what your question is. The method you described ought to work on Michael texture maps as well as P4M texture maps. I would put the scars/tats on a seperate layer though and try setting to layer to multiply or overlay. That seems to give me the best results.
"Do not meddle in the affairs of cats, for they are subtle and will piss on your computer." -- Bruce Graham
veamon posted Tue, 17 July 2001 at 11:40 AM
hmm...i have em on seperate layers, and i do the exact same method as i do with the p4, and p4 always worked fine...dont know what the prob is using michael ones...do i need to uncheck anything like "apply textures to highlight" or stuff like that?
Daio posted Tue, 17 July 2001 at 12:09 PM
No, you shouldn't have to. What you describe is the method I use to add scars and tats to Michael textures. All you need to do is apply the revised texture to skinbody or skinhead depending on where the scars/tats are. Try saving the revised texture as a .jpg file rather than a .psd file Every once in awhile a .psd file can be so big that poser doesn't seem to load it properly - though admittedly that just usally just tends to make my copy of Poser crash when I try to render rather than render the wrong texture.
veamon posted Tue, 17 July 2001 at 12:13 PM
k...thanks
