MindsEyes opened this issue on Jul 19, 2001 ยท 4 posts
MindsEyes posted Thu, 19 July 2001 at 7:58 AM
Jim Burton posted Thu, 19 July 2001 at 12:26 PM
Turn on the ground plane, or put some lumpy surface (object)in the right place and scale it up to the right size. You can also put a texture map or bump map on the ground plane, but it is pretty flat! Nice render, BTW!
MindsEyes posted Fri, 20 July 2001 at 5:40 AM
Thanx. I'll give it a try.
Edgar posted Mon, 23 July 2001 at 3:04 PM
Another thing I might suggest if you're looking to create a greater sense of depth is to put some back lighting in. Looking at your image I'm noting that most of it seems to be lit straight from the front (or the front light is wiping out the back light). Tweek around your front lights so they're coming in more from the sides... Maybe reduce their intensity a bit (or rather, reduce the intensity of the lights coming from the left or the right to get some shaping going on)... And then put a few lights in that are coming from behind. It cretes a sort of 'rim' around the objects and pulls them out of the background.
