overlas opened this issue on Jul 22, 2001 ยท 4 posts
overlas posted Sun, 22 July 2001 at 8:10 AM
I have some problems with my CDROM in windows, I have access to contents only in DOS mode. So, my question is: can i instal the POSER4 trough DOS?
Jackson posted Sun, 22 July 2001 at 9:18 AM
No. What problems are you having with the CD in Windows?
mheldt posted Sun, 22 July 2001 at 6:39 PM
If your system is that far out of wack you should consider fixing it before adding anything.
shadowcat posted Sun, 22 July 2001 at 10:59 PM
Your disk could be dying, you may want to consider copying the whole disk to your hard drive to be safe. Do you have this problem with other CDs? If not, definately copy whole disk (if you can) while in Dos. I had a similar problem with a disk just before it quit on me altogether (due to scratchs) Another thing to consider is replacing the CD-ROM driver, they may be corupted in windows (maybe?) If it turns out to be a bad disk you could try contacting curious labs, they may send you a new one if your a registered owner and have a registration code.
