Forum: Poser Technical
Subject: millenium null question
Darkworld opened this issue on Jul 26, 2001 ยท 5 posts
Darkworld posted Thu, 26 July 2001 at 4:58 PM
when i add a null to my scene, then replace it with a figure, THEN add a second null and replace that with a second figure, (using vicki) it still ends up missing tons of body parts; anyone know a better way to get 2 vicki's into one scene?
rbtwhiz posted Fri, 27 July 2001 at 2:34 AM
The correct way to load the figures is to first load the null, then with "BODY" on the null selected add the actual figure. Then... select the null [BODY] you loaded first and add the second figure. If there is a third figure, select the null [BODY] again and add it next. There is no need to add a second/third/etc null, you only use one. -Rob rbtwhiz.com
MartinC posted Fri, 27 July 2001 at 2:58 AM
And I always thought the millenium started with "01"... ;-)
Darkworld posted Fri, 27 July 2001 at 7:30 AM
Thanks! i figured it out. i was actually selecting BODY:1 from the parts list on the null, instead of just picking "body" before that (the no actor message had me thinking it wouldn't work... but it turns out that's the point) i added 4 figures to the scene and it worked great
rbtwhiz posted Fri, 27 July 2001 at 11:27 AM
Glad to read that you got it to work. -Rob rbtwhiz.com
