Subject: Train cars
thee_immortal_one opened this issue on Jul 28, 2001 ยท 17 posts
thee_immortal_one posted Sat, 28 July 2001 at 9:44 PM
A decidedly low rez train set.
box car
thee_immortal_one posted Sat, 28 July 2001 at 9:45 PM
tanker
another tanker
lalverson posted Sat, 28 July 2001 at 10:06 PM
Seems they need an engine, they look very nice tho
ClintH posted Sun, 29 July 2001 at 12:48 AM
Very nice work! Clint
Clint Hawkins
(Zakk Wylde (2007))
Huolong posted Sun, 29 July 2001 at 11:08 AM
Any one seen a coal car, the car that is normally attached to a steeam engine? I've got several steam engines and exceept for a Civil War era one, no coal cars. For those who never saw one, it's difficult to get a head of steam without one.
Gordon
Mason posted Mon, 30 July 2001 at 12:48 PM
Nice! You might want to think about running some of these through UVMapper and split the vertices so that Poser will flat shade them.
Nance posted Mon, 30 July 2001 at 3:16 PM
Huh? It'll do that? A little more detail please Mason (or Steve, or anyone) btw - don't recall if they had a coal car but a bunch of old rail meshes at this site by Raven Imaging. Though mostly low res, copyright.txt indicates they are free for use. The rail stuff, IIRC, was mostly in the /virtcons/ directory. Go to the /images/ directory for thumbnails, then find the .obj models in the /wave/ directory. Rail stuff under here
Lemurtek posted Mon, 30 July 2001 at 3:27 PM
The latest versions of UVMapper have new commands: Edit/Tools/Split Vertices Edit/Tools/Weld Vertices The split vertices will essentially unweld the vertices for each polygon in a model. This works globally, so is mainly useful for non-organic type objects, you'll lose all the smooth shading, and have a faceted look. Note that doing this can dramatically increase the size of the object as well. One final thing, the Weld vertices apparently requires the object to have normals included, which most programs don't export when saving an Object file. When importing an object into Poser, uncheck the weld Identical Vertices option if you want the flat shading to be preserved. Regards- Lemurtek
Huolong posted Mon, 30 July 2001 at 7:10 PM
Mason - Thanks for the information ... I checked the site mentioned and found download info for /obj files. On opening, they were text files with programming instructions (?) and I don't know butkus about how to use text files to recreate an obj file for use. Hilfe!
Gordon
Nance posted Tue, 31 July 2001 at 12:52 AM
Huolong, I assume you were replying to me rather than Mason. (Thanks btw to Mason & Lemurtek for clueing me in on the split-vertices to avoid smoothing thing.) Wavefront style .OBJ files are in fact ascii text files. To use the models from the ftp site I mentioned: -just download and save the .obj files to your hardrive (right-click on filename & "Save-Link-As"), -if there is a .MTL file with the same name, save that also. It will contain any UV texture mapping information for the .OBJ file. You don't have to do anything with it, just keep them together. -then, in Poser select File/Import/Wavefront OBJ/ and select the .obj file you downloaded. You will then get a bunch of check boxes to select importing options. You can leave them all blank, but you may want to check off the one that says something like "Make normals consistent", or somesuch. -You'll also have to fool around with the scale to get it the right size in Poser. When created in other programs, Obj files are usually scaled about a thousand percent too large for Poser models and rotated 90 degrees forward on the X axis. -After it is open, you can save it to your Poser library as you would a normal prop. The site also contains all the same models as .3DS and .DXF formats. The files look pretty old and it appears to have been a demo site for some file format conversion software. Hope something there helps.
Huolong posted Tue, 31 July 2001 at 12:57 AM
Ordinarily, an obj file downloads as such. What I get is a picture with text on it. I can save it as a gif or bmp, only. Do you suggest that I rename a bmp as obj?
Gordon
Nance posted Tue, 31 July 2001 at 10:48 AM
Hmmm... a picture with text? Dunno. There should be gif thumbnails in the "images" folder and .obj files in the "Wave" folder. Are you saying you are getting images from the files with the extension ".obj"?
Huolong posted Tue, 31 July 2001 at 12:46 PM
I saw no images, the above is what the DL looks like
Gordon
Nance posted Tue, 31 July 2001 at 11:06 PM
That's it! You are looking at the guts of an .obj file (or at least the first few lines). To save it, don't open it in your browser, just right click the filename link & save it to disk (if you are PC) and make sure the file name stays "crosgate.obj" (your image shows it named "crossgate_obj" with an underscore instead of a dot) Then, in Poser, just do the "File/Import/Wavefront Obj" thing as described above. I'll go try that one in particular to make sure it works for me.
Nance posted Wed, 01 August 2001 at 12:07 AM
Yup. Worked OK, but gads! my site is down so cannot post a pic. -Just a thought on what might be confusing things: If you are clicking the filename link, because it is not a zipped file, it will open in your browser as a normal text file rather than offering you an option to save the file. If you then select file/save in your browser you are probably saving it as a html page rather than an .obj file. May just be a filename screwup. Thats why you should be doing the right-click, save-file-as thing, rather than opening and then saving the file. When you try to import the file in Poser does "crosgate.obj" show up when you browse the list of available files?
