agate88 opened this issue on Jul 31, 2001 ยท 12 posts
agate88 posted Tue, 31 July 2001 at 10:07 AM
Poppi posted Tue, 31 July 2001 at 11:40 AM
Yup...Anton's pony would do the job. Actually, if you only have one hair...that is the one to get!!!
agate88 posted Tue, 31 July 2001 at 12:27 PM
Yeah, but are you sure? All of the example pics at DAZ show Anton's hair being fluffy in front, not flat and against the head like in the photo. If it's fluffy in front, it still has the problem of it needing to move when she is animated. I can handle the back part, but I don't want to animate hair from the front AND back.
amp-three posted Tue, 31 July 2001 at 12:30 PM
Heh, I've been looking for the same type of thing with the front part. Come on people! We are desperate! (Well at least he is! :)
agate88 posted Tue, 31 July 2001 at 12:35 PM
Yeah, come on! It's not like I have the people and resources of the Final Fantasty special effects team...I'm by myself here!
shadownet posted Tue, 31 July 2001 at 2:31 PM
Attached Link: http://www.horae.dti.ne.jp/%7Erakuto/
This may be a bad suggestion, but it is a thought. On the Digital Babes, there is a Nhair by Nesterenko that is similar to the front part. There is also a poseable ponytail. You might be able to combine the two to get the look you want. Load, say the Nhair onto the figure first and then save it to the "Props Library" as a prop (might want to parent it first and make it a smart prop). Then load it back onto the figure as a prop, and then load the ponytail hair. A bit of tweaking and the right texture and the two should blend well enough together to be made to look like the hair do in the picture. Just a thought.shadownet posted Tue, 31 July 2001 at 2:35 PM
Oops! Looks like the Nhair9 has replaced the nhair I am speaking of. Might be able to get the one I am talking about at Nesterenko's site. The nhair I downloaded sometime back is parted on the left and drapes across the forehead much like in your picture.
Cin- posted Tue, 31 July 2001 at 7:37 PM
VAIRESH posted Tue, 31 July 2001 at 9:18 PM
daeve posted Wed, 01 August 2001 at 12:38 AM
Use the hair that comes with LinLin (free figure - GREAT figure - forget where to get her, sorry). The bangs are identical to the picture, no pony tail though. If you add a pony tail it will work but some of her original hair will still drape over the front of her shoulders. LinLin is a p4 character but the hair can be sized for Vicki, as with all of Kozaburo's masterpieces. Daeve
agate88 posted Wed, 01 August 2001 at 9:56 AM
Thanks....I'll check out and consider the tips. But you know, for those of yout that design hair, this is a pretty cool style that I bet would sell well...
amp-three posted Wed, 01 August 2001 at 10:32 AM
You can get LinLin (and her hair) by going here. All you have to do is load the pz3, and delete the body (Figure 1), so that all that remains is that hair. Then add to your library.
