TyggerBob opened this issue on Oct 16, 1999 ยท 4 posts
TyggerBob posted Sat, 16 October 1999 at 5:52 AM
JeffH posted Sat, 16 October 1999 at 11:01 AM
It looks good as is, the shadow effect is perfect. I'd say reveal her face in another image that advances the story. The only problem I see is that dark shape under the torch, it doesn't seem to belong there for some reason. -JH.
TyggerBob posted Sat, 16 October 1999 at 11:20 AM
Thanks Jeff.. I am working on a second draft that has a couple more things lying around (like a box of firewood near the fireplace) and added a bit of fog effect.. seems to look good so far. I really like the spilled cup. Anyone here seen any fireplace tools around? I've hit up nearly every model repository I could find, but with no luck so far. As far as the additional light, I put another torch on the other side of the room (behind us) that's low and adds just a bit of light. WRT the dark spot, its the shadow of the torchiere.. should I make it so that the holder doesn't cast a shadow? I debated that, and decided to leave it in, even though I wasn't 100% happy with the result. Thanks again for the comments.. TyggerBob
JeffH posted Sat, 16 October 1999 at 11:57 AM
I would remove the torch shadow, it doesn't look right. -JH.
