omega opened this issue on Aug 03, 2001 ยท 8 posts
omega posted Fri, 03 August 2001 at 7:42 AM
I have created some large props and noticed that to get a figure to cast a clear shadow, I have to turn off "cast shadows". great! I get a good shadow from the figure but the prop no longer casts shadows on itself ( ie columns on floors etc) Is this a weakness in Poser rendering or is there a way around it.
doozy posted Fri, 03 August 2001 at 12:45 PM
??? When you turn off "cast shadows" the figure should cast no shadows at all. How about giving us a picture of your problem? If the problem is that the shadow is fuzzy around the edges, there are things that can be done to help that...
Miss Nancy posted Fri, 03 August 2001 at 6:06 PM
Another glitch was discovered (recently?) in Poser. If one adds a poser prop (or maybe even an imported prop) to a scene, then increases a dimension (or maybe all dimensions) of the prop drastically (perhaps 500% or more), the shadow-map calculations are screwed up. The end result is that props, perhaps even those that were not resized in any way, will either cast no shadows, or they will do so in an unpredictable or unsatisfactory manner.
omega posted Sun, 05 August 2001 at 3:01 AM
omega posted Sun, 05 August 2001 at 3:08 AM
Now if I uncheck "cast shadows" on the prop I get a good shadow from the figure. However if I bring in another prop with "cast shadow" checked the figure shadow will go back to that in the first picture
omega posted Sun, 05 August 2001 at 3:09 AM
doozy posted Sun, 05 August 2001 at 12:30 PM
omega posted Mon, 06 August 2001 at 7:06 AM
tried this:- doesn't help also 1024 seems to be the maximum
