pack opened this issue on Oct 19, 1999 ยท 2 posts
pack posted Tue, 19 October 1999 at 2:44 PM
sebulba posted Sat, 06 November 1999 at 4:19 PM
ray dream deletes materials, there's no way around it. but if your'e using p4 you can manually reset materials w/ grouping tool, save in prop folder, then edit cr2 to use maps. you must also remap uv coordinats exactly the same as before importing into rds. i recomend steve cox uv mapper. then paste original texture onto new uv map. save the new map, and done. if your'e not using p4,sorry i could not help. good luck ;-)
