Subject: Main window problem
grayhuze opened this issue on Aug 06, 2001 ยท 5 posts
grayhuze posted Mon, 06 August 2001 at 12:46 PM
My main window (the one with the character in it) is locked in the upper left hand corner. When I say locked, I don't mean the setting, I mean I moved it up there, and the title bar is hidden so I can't move it back. Does anybody have any help? I want to have the window in the middle, but can't figure it out. Thanks Gray
SWAM posted Mon, 06 August 2001 at 12:49 PM
Just klick on the arrow on top of the main window on the left side an move it where ever you want. But you also can move the "little bar" the same way. moenchen
grayhuze posted Mon, 06 August 2001 at 12:58 PM
That is the problem, look at the picture. I have fixed the problem however, by going to preferences and loading up the factory presets. Thanks anyways Gray
agamemnon posted Mon, 06 August 2001 at 1:10 PM
I would suggest you go to Window on menu and choose Resize. Resize to something much smaller than what you have. That would make the top bar visible again for you to move. I hope!
Glas posted Mon, 06 August 2001 at 4:04 PM
I had the same problem last week and summited a question in poser tech. forum. Scott A gave me the answer that worked. "Try going into the edit->GeneralPrefrences menu and select "Launch to Factory state". That should put your windows in a place where you can move them around and re-scale them again. ScottA " Once again Thanks Scott
