Chris opened this issue on Oct 24, 1999 ยท 6 posts
Chris posted Sun, 24 October 1999 at 5:05 PM
Attached Link: 3D Grafx Online
Someting went wrong with the import of my Poser model. The textures are wrong and trans maps are not imported. What did I've made wrong? hope you can help me Christian"It Is Useless To Resist!" - Darth Vader
PixelKing posted Sun, 24 October 1999 at 5:49 PM
Make sure all import boxs are checked.....if your texture isn't in the same location as the .OBJ it will instruct you to find it...make sure you select the same texture desired. Other than that....I have no other ideas....hope this helps.
JeffH posted Sun, 24 October 1999 at 6:08 PM
Only the T-map will go to bryce. You have to add the trans maps yourself. The Poser clothes have invisible parts that must be unchecked in the hierarchy before export as OBJ. You will know what they are by the grayed-out eye. -JH.
Spike posted Mon, 25 October 1999 at 12:02 PM
Chris; Do you do you want me to send you the tutorial? Spike
You can't call it work if you love
it... Zen
Tambour
Chris posted Mon, 25 October 1999 at 1:32 PM
Hi Spike, that will be great!! I've heard that your site is down, I'm sorry about that. Hope you will be online soon. Chris
Chris posted Tue, 26 October 1999 at 3:13 AM
Thank you all - Poser to Bryce works fine now. Christian
