Subject: Replacing default Body Parts to different
Todo opened this issue on Oct 28, 1999 ยท 2 posts
Todo posted Thu, 28 October 1999 at 9:29 AM
For example - i have default Poser figure and want replace it default bodypart to a different bodypart from .OBJ file. What i need to do ? If i select any body part and press DEL, then whole figure is deleted. Thank.
bloodsong posted Thu, 28 October 1999 at 10:30 AM
heya; you can't delete body parts, you can only make them invisible. you can open a figure and replace a body part with a prop. to do that to use a different body part, export that body part as an obj, then import it into your scene. place it over the body part you want to replace, and then 'replace body part with prop.' okay? :)
