Himalaya Joe opened this issue on Aug 15, 2001 ยท 3 posts
Himalaya Joe posted Wed, 15 August 2001 at 4:29 PM
Is there a way of controlling the smoothness of rendered objects in Poser? With imported objects any surface less than 90 renders smooth. The only workable solution around this that I've found is to increase the polygon count on the objects flatter surfaces. Surely there must be a lesser insane way to get flatter surfaces than this? Himalaya Joe
Miss Nancy posted Wed, 15 August 2001 at 6:26 PM
split vertices in UVMapper (Windows version). it doesn't work in the Mac version, so you have to use other tricks.
Jim Burton posted Thu, 16 August 2001 at 8:02 AM
Whey you model, put two edges up close to the corner, real close when you want a really sharp edge.
