NorleyS opened this issue on Aug 17, 2001 ยท 7 posts
NorleyS posted Fri, 17 August 2001 at 2:04 AM
kaom posted Fri, 17 August 2001 at 2:35 AM
Attached Link: http://www.awakemm.com/poserarcana/tutorials/rw/rw02/index.html
Go check out this site. It explains the whole process in detail,it's a very good place to learn your poser tricks. It will show you step by step how to do it correctly, and it's easy to follow. Good luck. kaomNorleyS posted Fri, 17 August 2001 at 6:39 AM
ringbearer posted Fri, 17 August 2001 at 9:48 AM
Try rotating the map 180 on the x control in the material editor. Seems like I read that somewhere, but I don't remember where. Hope this helps.
There are a lot of things worse than dying, being afraid all the time would be one.
Phantast posted Fri, 17 August 2001 at 10:07 AM
It should. That's the problem.
ShadowWind posted Sat, 18 August 2001 at 12:01 AM
I had this problem when the texture wasn't square...1024x1024 or whatever...
NorleyS posted Sat, 18 August 2001 at 2:26 AM
Thanks everyone for the tips. Turning the texture through 180 degrees worked a treat! I wish I'd asked earlier and avoided many hours of frustration!!
