Subject: Locking down an object
verbal opened this issue on Nov 05, 1999 ยท 3 posts
verbal posted Fri, 05 November 1999 at 7:59 AM
I would like to be able to lock an object to my model. I have this hair, I believe it's in an obj format. everytime I put my figure into a pose the hair remains in the same place it started. Has anyone delt with this before? Thanks a load, Verbal
LoboUK posted Fri, 05 November 1999 at 8:30 AM
What you need to do is position/scale the OBJ hair correctly, and then parent it to the figure's head. Then, you can either save it as a smart prop, or (better) save it in the library with the rest of your hair models. Paul
LoboUK posted Fri, 05 November 1999 at 8:33 AM
BTW: If it still keeps "leaping" from your figure's head, use Edit>Momorize>Element while the hair is selected. Then, if it takes a sudden sideways leap, you can just restore it using the restore option on the same menu Paul
