Forum: Carrara
Subject: Help - aliasing how do I turn it off or on?
datastorm opened this issue on Aug 22, 2001 ยท 3 posts
datastorm posted Wed, 22 August 2001 at 12:30 PM
I have Carrara Studio. How do I turn aliasing off or on. Where do I go?
litst posted Wed, 22 August 2001 at 2:35 PM
Hi Datastorm, Anti-aliasing is called "Adaptive oversampling" in Carrara . The options are located in the renderer settings (properties tray of the render room) . Set to "none" you'll have no anti-aliasing, set to "fast" you'll have a low quality A-A wich affects mostly aliased edges, and set to "best" the scene will automatically render in a higher resolution and then will be resampled to reduce the aliasing . Hope this helps, litst
datastorm posted Wed, 22 August 2001 at 6:57 PM
Thanks litst
