Octronmen opened this issue on Aug 23, 2001 ยท 3 posts
Octronmen posted Thu, 23 August 2001 at 7:59 AM
hallo User I please can only Deutschsprechen about entschuldigeung ich habe ein problem bin neu mit Poser und brauche hilfe! hier in freestuff gibt es viele Texturen von Kleidungen , wie kann ich sie in poser importieren so das die figuren sie anziehebn knen ? danke imvorraus f hilfe grudirk
perrick posted Thu, 23 August 2001 at 8:46 AM
I can understand German fairly well, but I'm not good enough to write an answer in German, so excuse me for answering in English. Hope you understand anyway: Textures and clothes are imported in Poser by placing the unzipped files in the appropriate folders. Textures goes in the folder runtimetextures (or a subfolder). The clothes consists of .obj files, wich belongs in an appropriate folder under runtimegeomitries and a .cr2 file, which you place in a folder in runtimelibrariescharacters. If you are a PC user, don't forget the .rsr files that comes with the .obj and .cr2 files, they must be placed in the same folders. When you download textures and clothes, they usually comes in a zipped file. The contributor is very often kind enough to enclose the folder structure in the zip file, so when you unzip the files into you Poser folder, all files will end up in the correct folders automatically. There are some turorials on the Internet about the Poser file structures which will help you to understand which files belongs where. Hope this helps, otherwise I hope there is some German speaking member who can help you further!
Octronmen posted Thu, 23 August 2001 at 12:16 PM
Hello thanks for her/its/their help, they don't need themselves for endschuldigen.I participates have report somebody thanks to bardas. Thanks again!greeting Dirk
