Forum: Photoshop
Subject: Cross Platform Help
kris opened this issue on Aug 25, 2001 ยท 3 posts
kris posted Sat, 25 August 2001 at 4:06 AM
My girlfriends Agent has just gone over to using a Mac. We however use PC's. Is there anyway of moving photoshop files from one to the other ? Will the layers be lost. I notice that when you make TIFF files, Photoshop asks if you want to make IBM or Mac versions. This would obviously remove the layers, but how can I get a mac to read the disc with the tiff file on it ? Kris
Jim Burton posted Sat, 25 August 2001 at 10:22 AM
Photoshop files (or all types) are fully tranferable between PCs and Macs, I do it all the time- just remember to add the extension .PSD on older Mac versions (I think 6 aand sometime 5.5 does it for you). The main differences, incidently, is the gamma, but newer Photoshops should ask you if they can convert, let it. Incidently, sort of a trivia question, but the difference between Mac and PC Tifs is PCs use LSB counting (least significant byte first) on numbers over 256, Macs (and most of the word) use MSB, but there is also a byte in the header that tells the App which one is used, so it really doesn't make any difference which one you set for a "proper" program. I'm sure you didn't want to know all that ;-) Oh yeah- do all your exchanging on PC disks, Macs can read 'em fine, as long as they have System 7.5 or better.
kris posted Sun, 26 August 2001 at 4:24 AM
Thanks Jim. That answers everything. Kris
