Binx opened this issue on Aug 27, 2001 ยท 4 posts
Binx posted Mon, 27 August 2001 at 2:48 PM
thgeisel posted Mon, 27 August 2001 at 3:05 PM
select the single lights and on the right side you get some dials where you can setup the resolution of the shadowmap and the amount of shadow for every single light. try higher resolution ( 1024 x 1024) and less shadow
gladiator posted Tue, 28 August 2001 at 5:27 AM
I usually put shadow on just one light. Try putting off the shadow on the other light(s) you're using. And as Pervers says increase the shadowmap resolution. The higher the resolution the more detailed your shadow becomes. Finally to make the shadow smoother turn down the shadow dial. I usually end up between 0.5 and 0.8 depending on the picture. You will have to experiment with this. Happy rendering
Nance posted Tue, 28 August 2001 at 12:02 PM
do both of those, (increase shadow map size & reduce density) but more importantly, to feather the edges of the offending shadow, zoom out the light's "Shadow Cam". You will get fewer pixels in the area of the shadow and therefore more antiailasing & a more diffuse shadow. (Shadow Cams are selected in the list of cameras on the button at the bottom of the display window.)
