farang opened this issue on Aug 29, 2001 ยท 5 posts
farang posted Wed, 29 August 2001 at 11:50 PM
Hi all I'm new to Poser. I got it a few weeks ago and haven't been able to put it down since. The real appeal of it to me is the ability to make my own little movies but I can't seem to make the DAZ figures walk. Not even the tech support person at DAZ seemed to have a good solution for this. Anyone here figured out this problem?
atthisstage posted Thu, 30 August 2001 at 12:21 AM
Oo. Walk Designer. Believe it or not, the tutorial in the manual is the best place to start. Follow it ruthlessly, and you'll get it. Trust me, it will work.
timoteo1 posted Thu, 30 August 2001 at 6:22 AM
Yeah, it'll work unless you want the figure to run. Otherwise you're out of luck. The WD is a cruel feature in that it looks like it will work beautifully until you actually try to implement it. Curious (or Meta) has needed to fix it from day one, and I'm not sure why they have not ... they are patently aware of it's shortcomings. But to answer your question, make sure you load the DAZ figures CR2 into the walk designer before you begin messing with the controls. -Tim
ScottA posted Thu, 30 August 2001 at 8:27 AM
There are some rules that need to be followed to make Figures WD compatible. What figures are you trying to use. And what are the problems you're having when you try to use them in the WD? ScottA
DocMatter posted Thu, 30 August 2001 at 12:14 PM
Whenever I use walkdesigner, I always have to spend hours tweaking the character...especially if its Vicky. WD seems to put a wicked hobble into her step.
