whoopdat opened this issue on Aug 31, 2001 ยท 11 posts
whoopdat posted Fri, 31 August 2001 at 10:54 PM
Varian posted Fri, 31 August 2001 at 11:23 PM
I think, for the eyelashes, the transparency needs to be inverted. Poser transmaps use white for solid, black for invisible; Vue uses them just the opposite. Easiest way to make the switch is to open the lashes material in the material editor, move to the transparency tab, and over by the transparency function (to the far right), change the upper function (the one that slopes from lower left to upper right) to the Invert (slopes from upper left to lower right). Just right-click the function and select Load New Function. Navigate to the "Other" category and select the Invert. That should help the lashes, I think, and it may also do the trick with the brows. You can give it a try at least? Good luck! :)
Axe555 posted Fri, 31 August 2001 at 11:56 PM
whoopdat posted Sat, 01 September 2001 at 1:11 AM
Well I'm not sure what I was doing wrong before, since I thought I was telling it to change that around, but I went and played some more and got it to work. I think I'm starting to like this. :) Thanks again Varian, and thanks Axe. That just saved me a LOT of headache. I'm looking forward to trying out a few more things now...like figuring out why Vicky's gladiator armor turns out funky. I'll play with that some more before I come back and beg for more help. :) Thanks again!
Varian posted Sat, 01 September 2001 at 2:47 PM
Axe555 posted Sat, 01 September 2001 at 6:55 PM
I hadn't thought of that Varian. Guess I made a foolish assumption that whoopdat was using Vue 4.
whoopdat posted Sat, 01 September 2001 at 8:10 PM
Varian had it right. Although, I may upgrade...have to wait and see a bit longer. But I still managed to flip it over right after some playing. I'm still fighting with it rendering things that aren't there (namely white masses) around Vicky's gladiator armor (everything besides the breastplate it seems). I'm sure if I don't figure it out soon, I'll be asking again since you folks are so helpful. :)
Varian posted Sat, 01 September 2001 at 9:43 PM
NP Rich, I would've assumed the same, 'cept Whoopdat had made a post just before this one mentioning the version. Otherwise...who knows what the heck I might've said! =:D Oooh, on the armor, try setting the Y scale to "-1.0" for the material. (I don't use Poser models enough to remember all this stuff up front, darnit.) The Y = -1 is helpful to remember, though. :)
whoopdat posted Sun, 02 September 2001 at 12:36 AM
I've been futzing with it on and off, but that's not something I would have thought to try. I actually thought that it was pulling the "white" off of the map, since there was a lot of white on it where there wasn't any part of the item. So I tried rendering it without any texture maps and still had the problem. I'll see how this goes. Thanks yet again. :)
whoopdat posted Sun, 02 September 2001 at 12:48 AM
I figured out why it was being goofy. It apparently decided it wanted to use the wrong texture. Here's the nasty part: my file names are very similar, and the textures themselves look almost identical with that tiny view. Sure enough as soon as I told it to use the right texture, I lost some white. Arg! Now I have to go and do it for several items. I even double-checked that I had it setup in Poser befoer expoting the object and I did. I'm not sure why it did that, but it did. Oh well. At least I know what's been going wrong! I'm sure I'll still have questions, but I think I'm done asking for today. :)
Varian posted Sun, 02 September 2001 at 10:40 AM
LOL, well welcome to the club! We've all had some "unexpected fun" with Poser items along the way. Glad you got it figured out. :)
