Johndalynne opened this issue on Sep 05, 2001 ยท 3 posts
Johndalynne posted Wed, 05 September 2001 at 5:57 PM
My poser won't convert obj files. Every time it does all of my commands turn grey? Also some of files that I import won't work because it's looking for an obj that is in the right directory, but it still gives the "cannot open * obj file" then gives me the " out of memory error" any clues?
leather-guy posted Wed, 05 September 2001 at 6:25 PM
Had a similar problem. Following a tip on this forum, I did a FileFind for FF*.arp files (the materials import plugin files), & found I had a duplicate set in my textures folder with different file dates. Deleted the dupes, leaving just the set in my runtime->plugins folder. Haven't had the problem since. Good Luck!
Viomar posted Wed, 05 September 2001 at 11:58 PM
Also, Poser might have corrupted the corresponding .RSR file!! Close Poser! Locate the offending .OBJ file in the Geometries folder, then delete ONLY the .RSR file! Then open Poser again, and reload the item! poser will rebuild the .RSR(Which is just a "Compiled" version of the .OBJ)!! Marco
