Trapper opened this issue on Sep 05, 2001 ยท 10 posts
Trapper posted Wed, 05 September 2001 at 9:27 PM
djthomas posted Wed, 05 September 2001 at 9:44 PM
Just out of curiosity, if you change your camera view and look at Vicki from behind, instead of rotating her, then render THAT image, are things still screwed up?
Trapper posted Wed, 05 September 2001 at 9:48 PM
No. If I change the camera view and look at her from behind, everything works fine. However, that isn't really a good option for obvious reasons. Kinda limits the scene. :) Any other ideas/suggestions???
djthomas posted Wed, 05 September 2001 at 9:56 PM
Have you tried (just for the hell of it) rotating the boots the same amount as you rotate Vicki? I know that if you select the boots to conform to vicki they should rotate as well, but...
Trapper posted Wed, 05 September 2001 at 10:04 PM
Yup. Thought of that. No luck. Only makes things worse. This is very FRUSTRATING! Thanks for trying to help!
Viomar posted Wed, 05 September 2001 at 11:25 PM
??? Does your Vicky have unconventional scaling??? I mean by that: If for ex. you scaled her thighs in the y axe to 120%, then for sure you'd need to make the same adjustments on the boots thighs manually... Yeap!! Conforming does not do those adjusments automatically! Give you an example: Load a default Vicky, conform some clothes to her, then scale Vicky at 200%. In Most cases, the clothes stay at 10o%... Have you tried looking at different angles but, with the "shading w/lines" option?? That way it's easy to see if your clothing is confroming to vicky properly... Oh!! i just thought of something! You must make sure that Vciky has "inverse kinetics" turned off for the legs prior to conforming boots, shoes.... i know that others will say that it's not necessary! But, after many experiments... Anyhow, Hope this info helps a bit... Marco
Taura Noxx posted Thu, 06 September 2001 at 3:30 AM
I found this aswell, sometime if I select the offending top boot part and go into it's properties, I can uncheck bend with figure or whatever that thingy is and it seems to pop back. :) Doesn't work all the time but it does sometimes ;-)
Questor posted Thu, 06 September 2001 at 5:55 AM
One thing you could try. Turn all IK off for the Vickie figure and then rotate her by rotating the hip not the body.
Trapper posted Thu, 06 September 2001 at 5:28 PM
Thanks for all the ideas! I tried 'em all, but the one that worked was from Taura Noxx. Thanks, buddy!! I can actually start using Vicki...like I should have been able to ever since I first purchased her last year. Tons of lost time to make up!!! Thanks guys/gals.
annemarie posted Wed, 03 October 2001 at 5:07 PM
DAZ would like to thank all those who purchased the Victoria 2.0 Morphing Clothing Pak 1 by John Brugioni. We particularly wish to express our appreciation for the patience of the few people who have had a problem with the pak. The free June 2000 update released by DAZ for the initial Clothing Pak 1 is required for John Brugioni's morphs to work. For anyone who purchased the Victoria Clothing Pak 1 before June 2000, please see the Clothing Pak 1 product page in order to get the update. This update must be installed on your system in order for the Victoria 2.0 Morphing Clothing Pak 1 to work properly. If you have any further problems or concerns please contact Betsy at tech@daz3d.com. Again we apologize for the confusion and appreciate your patience. Thanks, AnneMarie DAZ
