Forum: Animation
Subject: Building up an image in a special way...
Avatar1 opened this issue on Sep 06, 2001 ยท 2 posts
Avatar1 posted Thu, 06 September 2001 at 2:23 PM
Hello ! I would like a 'special effect' for building up an image on the screen : 1000's of pixels flying around, and eventually building up the picture in the end. Anyone can give a hint to wich program is able to produce such an effect ? Thanks in advance ! Rob.
MephistoLV posted Thu, 06 September 2001 at 5:25 PM
Adobe After Effects - production bundle - can do exactly this sort of thing using the Particle Playground feature. Use the layer exploder to create particles from your picture, adjust properties as desired to make them fly around, precompose the effect, and then reverse the footage to achieve the particles "becoming" the picture. Hope this helps you out. James Hartzell owner/operator - JLM Multimedia Enterprises
