Forum: Bryce
Subject: WIP - any suggestions?
Sihn opened this issue on Sep 08, 2001 ยท 5 posts
Sihn posted Sat, 08 September 2001 at 3:57 PM
I loaded this up in my gallery as well. Looking for some suggestions on how to soften some of the harsher lines and so on.
Tabazan posted Sat, 08 September 2001 at 8:05 PM
Looking good :) I'd be tempted to blur the edge of the light on the water a little, it'll help it look a little more real. T.
EricofSD posted Sat, 08 September 2001 at 10:20 PM
The light needs to ripple with the water. Ripple edges, some dark spots in the main part. What happened to you is that the water is a flat object with bump height in the texture rather than a rippled object. You can either post render ripple it with Photoshop or remake the water with actual contours in it. Try a flat terrain with one of the PTE fractals in it. http://www.chesco.com/~cjcigas/tutorial/pte/
EricofSD posted Sat, 08 September 2001 at 11:17 PM
Attached Link: http://annsartgallery.com/eric.htm
Here's an example of the different techniques I suggested above. The top image is a flat water with photoshop ocean ripple effect. The lower one is a PTE terrain flattened to 0.10 in height in the attributes section.
Sihn posted Sun, 09 September 2001 at 2:25 PM
Thank you, Eric. I'm going to try that second technique.
