Toby G opened this issue on Sep 13, 2001 ยท 5 posts
Toby G posted Thu, 13 September 2001 at 8:23 AM
I've opened up a .pz3 file I previously saved, actually all my .pz3 files, the props are there the hair is there. But the actually characters body has disappeared, I can sellect parts of the body but they are just not there. I've gone to properties to see if I've acciently made it invisible but it says its not. This happened once before when I first started using poser and a complete re-install seemed to fix it, but I've added soooo much stuff, I don't really want to do that. anyone got any clues?
Kelderek posted Thu, 13 September 2001 at 8:37 AM
Have you checked in the Hierarchy Window if the body parts are visible or not? The little 'eye' icon by each body should be white. If it is gray, that body part is invisible in the main window.
Toby G posted Thu, 13 September 2001 at 8:46 AM
checked, everything seems in order in the hierarchy window, still no figure, but thanks for the advice
shadowcat posted Thu, 13 September 2001 at 8:59 AM
Try the .rsr files in your geometries folders, figure out which bodies don't show up an which do. for example is it the P4 nude woman, the man, mike or vicky? if it is continually the same figure, delete that figures .rsr file in the geometries folders as they do get corrupted. Poser will then rebuild a new .rsr file.
Toby G posted Thu, 13 September 2001 at 10:42 AM
P4 nude woman .rsr was the culprit, thanks for the advice, all sorted now. phew :)
