Subject: LateXa's finger and toenail colors....how to change
psampang opened this issue on Sep 13, 2001 ยท 2 posts
psampang posted Thu, 13 September 2001 at 9:16 AM
Has anyone had any luck changing the color of LateXa's finger/toenails? In the materials editor I've changed the color, with and without a map, with no effect. Colored the nails red in the texture map. They keep coming out white. Any ideas? (I emailed the creator about a week ago and haven't received a reply.) Alternatively, but less desirable, anyone know where I might find a fingernail prop?
Cin- posted Thu, 13 September 2001 at 9:33 AM
I don't have LateXa, so I don't know how you'd go about changing the color of her nails, but you could create fingernail props right inside poser... just use the grouping tool, select the finger joint on the end with the nail, create a new group, add the material for "Nails" and then spawn a new prop... if the reason you can't change the nail color on Latexa (which this is what I'm betting is the case) is that the nails have been grouped into another material, you won't be able to spawn the nail props from LateXa, but you could do it with any other figure that the nails are still grouped to their own material and parent the nail to the appropriate finger, save them as "smart" props and then reload them onto LateXa... if you get completely lost and can't figure it out, and if there isn't any other nail prop out there, I could make them for you, just ask.
