markdc opened this issue on Sep 24, 2001 ยท 5 posts
markdc posted Mon, 24 September 2001 at 1:37 PM
Attached Link: http://briefcase.yahoo.com/markcusd
PInstall - the fast and easy way to install Poser library files. What is PInstall? PInstall is a standalone application which allows you to install poser library objects (characters, poses, textures, etc) without needing to figure out which files go in which Poser subdirectory--PInstall does it for you. You don't even have to unzip library files stored in zip archives. Also, you can use PInstall to unzip and install a variable number of archives automatically! Includes: Multi-unzip utility This utility allows you to unzip any number of zip files to a directory of your choosing without placing files in the Poser library structure. You can use this utility for mp3s, images, max or any other files that you download from the internet. Download demo from attached link or go to utilities in freestuff.nitreug posted Mon, 24 September 2001 at 4:23 PM
I just try your tool but where do you put a pz3 file? I did a search in my poser directory and cannot find it!!!
Sherlock posted Mon, 24 September 2001 at 6:57 PM
Does the install maker test to make sure certain geometries previously exist? Something like that might encourage Daz to losen Vicki2 add-on requirements.
jamball77 posted Mon, 24 September 2001 at 7:43 PM
thanks I really appreciate THIS utility.
markdc posted Tue, 25 September 2001 at 12:22 AM
nitreug, Select Tools > Additional Options There you can set a path for .pz3 files. These files can go anywhere you want. Sherlock, No it doesn't.
