deadboy opened this issue on Sep 25, 2001 ยท 4 posts
deadboy posted Tue, 25 September 2001 at 2:10 AM
I love using Carrara for text among other things. But I cant figure out how to export the text to lightwave for further processing. Im pretty new to 3d.
ewinemiller posted Tue, 25 September 2001 at 6:58 AM
deadboy, You should be able to export from Carrara to an OBJ file and then import it into Lightwave. I haven't done it in 6.0, but there used to be a way to bring OBJ files into the modeler in 5.6. Good Luck, Eric Winemiller Digital Carvers Guild Freeware and commercial 3D extensions http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
deadboy posted Tue, 25 September 2001 at 1:07 PM
Thanks Eric, I did try exporting in a few different formats. Lightwave seems very picky and I get really frustrated having so many problems with such an expensive application.. It seems like Carrara excells at many things that Lightwave falls short in...like being very stable and predictable. I posted because I thought there might be something I was doing wrong in the export / import process...The main reason I wanted to export the text is becase LW has more shader options (at least in my limited experience) and it renders quicker. If I had more shader options and could render quicker in Carrara I would just use that for text..If anyone else has an ideas please post it. thanks
rockjockjared posted Wed, 26 September 2001 at 2:03 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12385&Form.ShowMessage=411747
deadboy, you'll have to go in and enable all of your plugins. See the link above for a little more info.
