7thGuest opened this issue on Sep 25, 2001 ยท 5 posts
7thGuest posted Tue, 25 September 2001 at 5:40 AM
PhilC posted Tue, 25 September 2001 at 9:15 AM
A CR2 file calling up an OBJ file containing body part grouping includes "Weld" lines in its script. Replacing body part with prop does not. The solution is to either write a hierarchy (PHI) file and bring the model into Poser that way or edit an existing CR2 to point to your model. Do this by opening a suitable CR2 file in a text editor. Then search for the two instances of the OBJ file path. Rewrite these for your new OBJ.
7thGuest posted Tue, 25 September 2001 at 6:13 PM
I imported several OBJ files (one for each body part). Does this mean I must point to all of them in the CR2 file? Thanks a lot!
7thGuest posted Tue, 25 September 2001 at 6:20 PM
Strange, but I peeked into the CR2 file of the new figure I made (replacing body parts with props) and I did see the "weld" lines in the code. But I'll do as you said and try writing a PHI file with PHI Builder.
7thGuest posted Wed, 26 September 2001 at 4:44 AM
