rbtwhiz opened this issue on Nov 24, 1999 ยท 1 posts
rbtwhiz posted Wed, 24 November 1999 at 11:16 PM
Robert McNeel & Associates have released the latest version of the 1.1b. Beta 24-Nov-1999 expires 31-Jan-2000. This build requires Rhinoceros 1.0 to be installed, and requires an unlock code. An unlock code will be e-mailed to you when you download. If you have more than one copy of Rhino, you will need a separate unlock code for each Rhino 1.0 CD Key. New in this build: - Preview image for 3DM files. - SaveSmall lets you save files without render and analysis meshes. Use the SaveSmall command, or the Save small checkbox in the Save and Export dialog boxes. - Dimensions now are exported to AI, WMF, DWG, and DXF files. Dimensions are imported from DWG and DXF files. - Improved support for BMRT and POV-Ray. - PolylineOnMesh snapping improved and now obeys object snap settings. - ChangeDegree has an option for Deformable=Yes/No. - Many bug fixes and stability improvements. For complete details, please visit http://www.rhino3d.com/beta/beta-notes.htm -Rob
