Subject: Daz Calander contest question
Bia opened this issue on Sep 26, 2001 ยท 3 posts
Bia posted Wed, 26 September 2001 at 11:02 PM
Hi, I am wondering how one gets the out put (or how to render) the picture the size that Daz asks for. I try to set Poser to render at certain Pixel by certain pixels and the aspect ratio seems to be locked. I can't see a way to unlock it... I wonder about the same thing in Bryce...while I can unlock the aspect ration, when I try to render the size Daz wants...the meshes seem to just look awful! What am I missing? Thanks
Artalgo posted Thu, 27 September 2001 at 1:17 AM
In Poser, try going to the Window menu and selecting Document Window Size. Make sure Constrain aspect ratio is unchecked and put in coordinates set to the proper ratio. (I would use 550 x 425.) When you go to the Render Options, you should be able to specify 3300 for the width and the height should automatically be set to 2550. I'm not sure what your problem in Bryce might be. My renderings at the size DAZ wants look fine and have no problems with the meshes. In the Document Setup I set the size to 1100x850 and then select a render resolution of 1:3. Of course, while I'm working on the picture I set the size down to 550x425 or else I can't see everything in the window. Hope this helps.
Bia posted Thu, 27 September 2001 at 9:00 PM
I will try this...I think I understand.
