Subject: Removing Morph Targets from characters
zoozI2000 opened this issue on Sep 29, 2001 ยท 5 posts
zoozI2000 posted Sat, 29 September 2001 at 12:51 PM
Attached Link: http://digilander.iol.it/zoozi/index.html
Wow, that's the second question I ask today, but I really have to ask. :) How do I remove a morph target from a character, I checked in poser itself and didn't find an option to delete, only to add more. Thanks again... Aya (with a million question, but never enough time to ask them all)
milamber42 posted Sat, 29 September 2001 at 1:37 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=413208
I have been using Morph Manager. There is also a program Morph Master that has a new version posted to free stuff today. See the attached link to a message about morph manager.
Miss Nancy posted Sat, 29 September 2001 at 2:37 PM
in Poser 4, select the figure, open hierarchy editor, and check "show parameters" then select the morph you don't want, and delete it the hierarchy list will be refreshed, this time without the offending morph
Mason posted Sat, 29 September 2001 at 8:28 PM
If you use poser be real careful and make sure the MT stays hilighted in the heirarchy list. The window doesn't work quite right sometimes and you can accidently erase the character instead of the MT if you're not careful. Either way works just fine.
dwilmes posted Sun, 30 September 2001 at 7:39 AM
If you have CR2Edit, a 4th alternative would be to drag the morph/s to the trash can. Dan http://www.zenwareonline.com/cr2edit/cr2edit.html Sorry Win only for software http://www.zenwareonline.com for ZenPaint, ZenTile, ZenGrid and VueMaster
