Subject: trouble with Mimic
koz opened this issue on Oct 04, 2001 ยท 5 posts
koz posted Thu, 04 October 2001 at 7:50 PM
Having trouble with Lipsinc's Mimic Program. Used to work fine in Poser 3, but won't sinc properly in Poser 4, dropped frames, jerky and unstable animations, etc. I am also using Pro Pak, could that cause a conflict? Thanx in advance for anybody's help. -KOZ
jamball77 posted Thu, 04 October 2001 at 9:09 PM
Attached Link: http://3dtutor.homestead.com
I use mimic and have a FAQ I've put together. I started out with Poser 4 and have had PPP since the beginning. I haven't noticed any problems. Ver 4.0 without the 4.03 patch used to give a lot of problems with randomly inserting foot movements, but that wouldn't be affecting you. I can't help other than to say it works with my setup.
hpalan posted Thu, 04 October 2001 at 9:57 PM
I've got PPP and Mimic and it works fine. For use on Vicki you have to edit the pose file or the eyeblink won't work but otherwise it's OK. Good luck. HP
jamball77 posted Fri, 05 October 2001 at 5:24 PM
My FAQ gives 3 easy fixes for the Vicky blink problem.
lynnJonathan posted Mon, 08 October 2001 at 12:21 AM
Works fine for me too but I do have a question. Mimic shows the sound file being 30 frames long and when I apply it in Poser its 34 frames. Shouldn't they be the same?
