Subject: Can you help me with Tiziana?
babar999 opened this issue on Oct 08, 2001 ยท 6 posts
babar999 posted Mon, 08 October 2001 at 1:18 AM
I cant seem to get Tiziana going. I converted the Tiziana_2.pcf to a Tiziana_2.obj file and done everything else i supposed to do but when she loads i cant see anything. I dont have a Tiziana rsr file in the geometries folder. Im i suppose to have that? Plese hurry up guys....I really want to get starting to work on that pu....OOOPPPS...sorry. Babar
JeffH posted Mon, 08 October 2001 at 1:54 AM
Where is the Tiziana download? Store, FreeStuff?
babar999 posted Mon, 08 October 2001 at 5:01 AM
Attached Link: http://www.eddy-show.com/models/
Tiziana4Vicky
JeffH posted Mon, 08 October 2001 at 9:54 AM
Attached Link: http://www.eddy-show.com/models/Tiziana02.htm
Okay, I got the link to the .pcf, I'll check it out and get back to you. -JH.
JeffH posted Mon, 08 October 2001 at 10:27 AM
Here are the directory paths you should have if you correctly installed the "Tiziana_02.pcf". Remember, all names in Poser are case sensitive. "RuntimeGeometriesapgeometrieTiziana_02.obj" Examine your folders and let me know if it is the same. Also, are you using Poser4.03 or the Pro Pack? -JH.
shadowcat posted Mon, 08 October 2001 at 12:54 PM
A corrupt file maybe, try converting the .pcf file again? As far as the .rsr, poser makes one of those after it loads an .obj file (the one that is paired with the .obj is a short-hand version of the .obj itself so that it will load faster, it is not a required file) I've also had blank figures load up before generally caused by a corrupt .rsr, but since you say you haven't got an .rsr it could be the .obj itself.
