Forum: Photoshop
Subject: The colors is wrong!
Narasha opened this issue on Oct 09, 2001 ยท 12 posts
Narasha posted Tue, 09 October 2001 at 5:53 PM
Attached Link: My site:
Hi. I have some difficulties with the colors in Photoshop. After I've made them image as I want it and save it, the colors look different in all other programs including the net. It is much bluer. When I want puple I get blue. It's quite distubing since I like purple. ;) Please help me if you can.
RJH posted Tue, 09 October 2001 at 11:54 PM
I am seeing purple on your site
Narasha posted Wed, 10 October 2001 at 3:18 AM
Attached Link: http://pathway.mine.nu/Narasha/
Yes of course. But if I want purple I have to guess the color in Photoshop. And in Photoshop those purples are almost pink. :-P
jayarraich posted Wed, 10 October 2001 at 10:57 AM
Photoshop uses color management. Most other programs don't. Your monitor profile is probably off. Run Adobe Gamma again. Also, be sure you have your RGB working space set to sRGB, or use the generic Web Graphics Defaults preset. [Adobe Gamma is found at Start > Settings > Control Panel in Photoshop 6; at Photoshop/Calibrate folder (Windows) or Photoshop/Goodies/Calibration folder (Mac OS) in 5.5. Color settings are found at Edit > Color Settings in Photoshop 6, and at File > Color Settings in earlier versions.] -Jay Arraich
Narasha posted Wed, 10 October 2001 at 10:59 AM
Thank you very much jayarraich! :) I'll try that!
hazadus posted Fri, 12 October 2001 at 1:32 AM
i also see purple grrrrrrrrr rounchie
Narasha posted Fri, 12 October 2001 at 1:35 AM
hehe..
DarthRage posted Mon, 15 October 2001 at 9:06 AM
What color mode are you working in? If it's cmyk, it will mess with the colors...
Narasha posted Mon, 15 October 2001 at 1:17 PM
RBG.. I only use CMYK for printing...
DarthRage posted Mon, 15 October 2001 at 2:01 PM
Right, that's the way it should be.... Are you using different percentages of the colors? gradients? When a color is a 100% it can look totally different at 70 or 60, because some of the other shades it's made of can become more dominant. In your case it would be the reds... I'm not sure if that's the problem, but it's a big possibility.
Narasha posted Mon, 15 October 2001 at 2:06 PM
Thank you DarthRage but I am quite certain that jayarraich's tip will help. Otherwise I will try yours ;)
bonestructure posted Mon, 22 October 2001 at 2:50 AM
setting your monitor up to run om adobe gamma is the vital thing. I've found that as long as I do that, the colors in all programs I use stay the same throughout any transition
